Guys, I need to get some thoughts to help make sure I'm not overlooking something obvious. My motor seems to have developed a high rpm miss. It happens at ~6800rpm. It will sometimes occur in 2nd gear, but always happens in 3rd gear just past the 1000' mark.
Looking back, its possibly been going on some time. On previous track trips the car would lay down just a hair going thru the traps @71-7200. I can feel the front end drop down just a bit and the motor feels like its on the rev limiter.
Last night it started showing up in 2nd gear on 3 out of 6 passes, and in 3rd gear on all the passes.
It also did this last week on the chassis dyno during the last pull. It didn't occur till right at 7k and was just a blip just before I let off. On the 2nd out of 4 pulls the motor ran clean to 7300 without a problem with only a few hp drop from its peak @6900.
My first thoughts are:
1-Valve springs
2-ignition (wires, rotor, cap, coil)
I don't believe its fuel related. Today I checked fuel flow out of each side of the regulator independently and together. Both hoses together will push out 2 gallons of fuel in 20 seconds. Each side alone will push 1.75 gals in 20 seconds. So, there appears to be plenty of fuel.
Next- I plan to check seat pressure on the springs. If nothing turns up I'll move on to the ignition. The wires, cap, rotor, and coil are all around 3yrs old.
Am I overlooking anything simple or obvious that you can see???
TIA.
1-Valve springs
TIA.
