1 - 18 of 18 Posts
Background:
I recently rebuilt my ZZ502 after a distributor gear broke and destroyed some bearings.
When I did the rebuild, I replaced the oil pump with a new one of the same model that was previously installed. The pump was okay when I pulled it, I only replaced as maintenance since I was in there already. The pump is a Melling M77HV, which is their High Volume pump.
In doing my install I also added some gauges, including electronic oil pressure, so I could better monitor my new build and the like.
I did a 500 mile break-in and everything is running really well. I also installed a Holley Sniper EFI, which is also running very well, but that is another story...
I mentioned my oil pressure in passing to somebody that has much more knowledge than I do and the response was, "that seems high and you might want to look into that".
So here I am.
I have read that 10psi per 1k is pretty acceptable for the BBC and my number are high. I have also read people say this is fine. I have reached out to Melling and gotten some responses (very quickly I might add), but I am also curious as the general consensus here as well!
Details:
I am running Royal Purple 5w-20, I broke in with the RP break-in oil, which I believe was 10w-30. My pressures were basically the same between both oils as I think should be expected. I use a Mobil 1 Filter.
  • At hot idle, my pressure ranges from 38-43 or so.
  • Driving around I see in the 55-60's
  • When I get on the throttle, I see max around 70.
A few questions:
  1. Is this something I need to be worried about?
  2. Could this have been what put too much stress on my distributor gear that broke it after ~8-10k miles before?
  3. If the pressure is too high, do I have any other options that don't require me to pull the engine to replace the pump?
That's about the same pressures my 454 had, I installed that same pump when the motor had 22,4xx miles on it and I had also replaced the RV cam for another hft cam, and NO problems, kind of wishing I used that pump on my roller 489 instead of the M77 with dark spring...but it's fine, so's yours IMHO
I have almost 7K mi on my Engine that was built Jan of last year and still going strong. My pressures are almost identical to yours. I'm running Maxima 10W-30. Have run RP 5W-30 as well with same results.
Mike
I just thought you were tripling down that he was good. HAHA.
Mike
Reactions: 77 cruiser
Ya that's the ticket.
That oil pressure looks fine to me, too. What does your water temperature get up to? Does your engine run cold (160* thermostat?) Remember that your oil needs to get over ~212F to boil off moisture that invariably gets into the oil.
My peanut port engine had a High Volume pump in it a couple of years ago and that engine would have 80psi cold and 40 warm but at WOT it was 80psi again. When I decided to replace the rings and bearing again I had oil in every cyl more than it should be. This time I used the std. pump now is 50 psi idle and 60 WOT. When when it comes to oil pressure more is not always better.
Had my BBC Rebuilt in late 2017 // went Roller Cam/Rockers/stock Oil Pump // did the 500 Mile Breakin in early 2018
// went Racing in 2018,2019,2020 plus as much Cruzin as the Weather permits for 6 months a year here //
Valvoline Synthetic 15W40 & NAPA - NGF 1060 Filter
Just back from a little Cruz and the the Oil Preessure at Idle = 30 - 35 psi and 40 - 50 psi at higher Rpms
do not know what she does at the Track as to busy Racing and trying to beat the other guy !!
All good, run it and put some miles on it.
Reactions: shovelrick
MY BBC with the same pump will hit 85PSI at 6700 RPM... and yet has around 30 at idle.
Discussion Starter · #17 ·
Thanks for the input/confirmations to all that responded! It helps put my mind at easy as I drive the heck out of this beautiful machine!
If you are just utilizing the electric oil pressure sensor and not a hard gauge just change the oil pressure sensor and you will get a slightly different pressure indication.
Car Vehicle Wheel Tire Hood
in my opinion a hard gauge is the only way to go with a new rebuilt engine. Even my 1965 Malibu SS came stock with a hard oil presure gauge runs 35- 60 psi all day.
1 - 18 of 18 Posts
