Hi Guys
Got the horns working, now just the high beam indicator and the brake warning light, to fix and everything works! Does anyone know which wire from the dimmer switch powers the high beam indicator light? I want to check it for 12v when high beams are on.Tried gounding brake light wire and still nothing so i need to chase that out too. Oil light works and all bulbs are new so thats out.
Steve
Hi beam wire is light green. However, if your outside high beams are working there is power on the light green wire on the dimmer switch.
The inside high beam indicator wire ties to the inside bulkhead connector pin. There is a remote chance of a problem here because the outside lights are working. Most likely there is a problem around the inside indicator light bulb.
Measure the wire on the inside bulb to a known good ground as a first step.
My Hi beams do work so the light green wire is OK. I was trying to find out what color wire runs up to the connecter in back of the dash to power the indicator light. It would have to be just one wire for that circuit i would think.
