Got some fine tuning issues going on here. Please feel free to offer advice.
My Dads 67 cruiser has a 350 with a 4 speed and 3.55 gears. The 4 speed is a M21 and the rear is just a 8.2 with a locker in it.
The motor is basically a zz4 short block with a UDHarold hyd. roller cam with 280/288 and 226/234 @ .050 duration with .530/.530 lift on a 108 lsa. The compression is right at 10 to 1. Heads are Brodix 180IK with Crane Energizer rockers. Intake is a RPM air gap with a Holley 650 Double pumper. Dizzy is a Stock GMPP HEI with a blue and silver spring in it with a aftermarket module.
Timing is set at 36* all in by 2600 and the can has been modified so that it 12* of additional timing for a total of 48*. The initial timing falls to 19* and with the can hooked up idles at 31*.
We are having some slight run of issues. Not much.
The throttle blades are turned so that idle is right at about 900 rpms.
Once you have taken the car for a spin and shut it off it will not die there is slight hickup and then shutters off. We run nothing but 93 octane in the car.
If I put in first gear and easy the clutch out while turning off the key there is no issue.
If I turn the throttle blades down another quarter turn, there is no run on, but the car seems to struggle to stay cranked while idling . When you turn the throttle blades back up a 1/4 turn, it idles fine.
Anyone have any suggestions?
