I'll try and make this short. I have a 72 Chevelle with a 307. My Velle was doing fine and one day the carb went bad. I had a 2bbl and decided to change over to a 4bbl. Everything was great, ran much better and love the extra ooomph, but once in a while it would have trouble starting. It would start but at first it wouldn't turn over at all and then eventually it would catch and then start.
So, I started fiddeling around and found a wire that used to attach to the front of the 2bbl carb but no spot for it on the new Edlbrock 4bbl. It was starting without it so I left it alone and tucked it in. The change over to a 4bbl is the only change prior to its problem of starting only every other try and it more often than not it takes a lot of tries and jiggling etc. to start.
I have had the battery checked, was told it was good but didn't have full cranking amps. Maybe 75-100 amps low. Alt. is putting out a good charge. I even pulled the starter and took it in and it was fine.
The problem is hit or miss. Once in a while it starts right up and real quick, one or two turn overs. Other times it has to turn over 8 or 9 times. Other times it acts like a dead battery and starter doesn't budge, or it just turns over half way or clicks a little (an electric clicking noise more than mechanical). I cleaned all battery connections and checked all the wires as best I could. Once the car starts it runs fine and lights and electonics don't dim.
Any advise?
Brian
Any advise?
Brian
