I am having some problems fitting a 6.0 LQ9 in my '72 Chevelle. I have the F-body pan which was suppose to have a 1/4" clearance to the back of the frame from other installs I have read about. My pan is touching the back side of the frame. I am using 1" setback (3/8" thick) plates already and was looking at some that could go up to 1.5" back but I don't think they will fit on my block. The 1" setbacks are already touching (what appears to be) a mounting boss of some sort at the top of the plates and just ahead of them. To get more rearward block movement I would need the plates to move forward (be longer).
From other installs it sounded like the F-body pan would clear the steering control arms and with mine the grease zerks hit on the pan. I could see trying some 1/4" shims under the mounts but I don't think that is going to be enough to clear the linkage. Do you get the same result if the shims go under the frame mount or the engine mount.
