Few months ago I had problems with my heads on a new engine build. The guides were shot. I took them to the machine shop and paid a ton of money to have them fixed. Well I had a bad knock on the motor that magicly went away a couple days ago. While investigating I found that one cylinder only had 70psi of cylinder pressure. So the motor came out thinking that I had blown a ring land or something. Got it apart and the top of 2 of the pistons are beat to complete hell but the cylinders look great. I notced the valve seats had shiney marks around them so I pulled the valves and the guides are shot. I can wiggle the valve about a 1/4" inch. One of the guides had the bottom part of it broken off and thats what beat the hell out of the pistons, and the suspected knock. The valve seat on the cylinder that had low pressure was worn out and not sealing anymore because of te guide.
I dont know what to do. should I go fight the machine shop? I have around 1000miles on this motor and only 12 quarter miles passes. My short block seems fine but I think im gonna have to replace the pistons that got beat up. What would cause the guides to wear out so bad?
