OK I am 99% done restring my 69 chevelle.
I installed a painless muscle car harness which was actually not too bad to do until now. I have everything working except for the RR turn signal/brake light. I got the LR working after working on the turn signal switch but cant seem to get the RR to work. I tried to use a circuit tester and I am getting no voltage anywhere in the circuit from the steering column or at the tail light itself. The parking lights all work fine. I dont quite understand how that circuit works and which way the power flows. Any help would be greatly appreciated.
ReCheck all your grounds I did the same thing and it was a bad ground.:yes:
And you had on working and one not from a ground? I didnt think it was a ground since the parking lights work and the LR works because they are grounded together. But I am going to recheck it now.
1 bad ground will do some weird things to your electrical system.
