I know that the cam for this engine needs to have a oil groove in the rear journal. So when I called Summit to order, The guy said that he has never heard of this. So I called the manufacture (Comp Cams) they said that it does need a rear groove, and I should pull the old one out to make sure. Im not quite ready to pull the engine apart yet due to other parts for the car need to be installed (taking up space in the garage). Although my mind is pretty well made up on ordering the grooved cam, what are the odds that this cam will be wrong? Im going to order it before disassembling the engine. Probably tonight or tommorrow.
Big thanks to all of you and sorry for the long post. Chris R
