1 - 20 of 39 Posts
I have a 1966 Chevelle 327. I bought the Edelbrock top end kit #2099 with the retro cam #2201 for the early blocks that didn't have a hydraulic roller cam. After taking my top end off we found out that my block is no good. I'm stuck with this kit from Edlebrock and no bottom end to put it on. Does anyone make a Gen 1 block I can use, or is there a new block out there someplace. I have been calling all over Texas and nobody can give me a solid "yes this block will work with that kit". Do any of you guys have any ideas for me. I need to buy a block within the next few days. Any help would be greatly appreciated. Thanks
The block is not completely bad the shop told me that .030 over could fix the scratch. I just don't have the $2600 for the machine work.
Just to clarify, Your shop want $2600.00 to bore the cylinders? :confused:
Wait....first off...$2600 for machine work....are you F'in KIDDING ME!? Run from that dude...If your looking for a 327ci block that is going to be hard to do. 350ci is much easier. To run the camshaft you will need a set of RETRO FIT hyd roller lifters the hyd lifters the block orginally used wont work.
Yes $2600 to bore and purchase the new items. I would still need to pay my engine builder after he gets the block back. So that is $2600 plus whatever my engine builder is going to charge to build it.
Yea I already have the roller rockers and roller lifters
PM Sent. You can use any 350ci block for the kit. If you use a newer block, than you have to use the proper flexplate to match the 1pc seal. Im curious to see what this $2600 intails....
Purchase WHAT "new items?" Just what exactly would you get for $2600 besides an overbore?
I'm not sure, because I didn't talk to him. My engine guy called him, and after that he said that was too much and to look for a short block if possible.
Wait, doesn't your "engine guy" know? Or is this a " Wanted 66 SBC block " ad?
I think what's being lost in translation here is that $2600 for an overbore is so out of the realm of reality that's it's laughable. You could have 10 blocks bored for that. So, 1. Either that shop is trying to take your money, or 2. There's more parts needed that you don't know about or 3. Your engine builder did not communicate well with the shop. Sounds like the shop is quoting you the price for the Eddy top end kit too and from your post it sounds like you already have that. If all it needs is thirty over find another shop and pay your $200. What a mess.
WOW 2600, I had all my machine work done crank turned,bored 30,cam bearings installed and freeze plugs heads reworked with new vavle and springs with engine kit cost me 936 dollars for a 454.I put the motor together.That guy is crazy.
stage 11 you are being ripped off.call mike lewis [wofeplace] at least i know he will tell you strait ,and he may be able to help on short block or other parts as well.dont let the machine shop keep your block either.good luck with your project.
In Memoriam
run, don't walk in any direction that's away from those guys. Sounds like they're both trying to use you to fund their trips to Hawaii.
No comments re: vaseline.....
You can get a complete 327 long block from Schmucks for about $1900.00 and change
1 - 20 of 39 Posts
