what car ? what year ?
look indeed at this site :
http://www.inliners.org/
they have all casting numbers for the Chevy L6 engines ...
pay attention to the number itself , it should be casted on the block , while the number you gave is probably the serial number of the engine , punched on the flat pad near the distributor .
I'll take a look at my engine to tell where the casting # are casted
Regards ,
Laurent
Just had a look at my engine , the casting # on a Chevrolet inliner 6 is on the right side of the engine , just to the left of the right engine mount , under the two pushrods covers , it should be in 6 numbers , no letters at all ...
Mine is 828 575 .
Regards ,
Laurent
Administrator
I'm showing TF to be:
1966 230cu 6cyl 140hp manual trans C10,C20,C30
1967 250cu 6cyl 155hp manual trans C10,C20,C30
1968 250cu 6cyl 155hp manual trans C10,C20,C30
