Guys,
I've had a thread about this in the past, but I want to try it again. Some of you have been helping me attempt to put an older reverse idle spreadbore holley on my car. Well last night the carb left me stranded on the side of the road. I opened the hood and gas was pouring off the secondary shaft. I took the cleaner off and about 1/2 inch of gas was sitting on the secondary blades with fuel still pouring in off the venturis. I hit the secondary bowl assuming the float had stuck. I tried restarting and once again fuel just came pouring out of the secondary venturi......... needless to say. That carb is coming off. My other weirdo Holley/Weber carb is going back in till I can figure out what I'm going to do.
This Holley/Weber carb does not have transfer slots. I haven't a clue where the blades are supossed to be tuned to. Any ideas here guys? This is a picture of the secondaries. You can see the dirty marks on the carbs from where it is normally closed around. If I completely back the set screw off the blade will just barely completely shut off the top of the upper hole (the upper hole of the pair) not the one really far up.
I've made the assumption in the past it should rest between the two holes, but I really don't know. Any ideas?
http://s200.photobucket.com/albums/aa265/dauber65/Just Carb/?action=view¤t=100_1297.jpg
