Below is the current configuration that I want to put a price tag on (I already have my ideas but looking for a little feedback). I came across a really good deal on a larger motor so that’s the only reason I am willing to part with this motor. This is not an ad to sell so please don’t inquire using this forum.
427 (.060 over making it a 439 ci) studded two bolt main Mark IV
Steel crank 3.76
I-beam Rods 7/16 bolts (rated to 700+ HP)
SRP Forged Pistons (10.1 w/ current heads 118cc chambers)
Large Ovals w/ 2.19 int. 1.88 exh. Valves (Stainless steel back cut as well) nice heads
Comp Cams XS274 solid cam (Pulls real hard but you could probably go a little bigger with the right gears.)
Aluminum Roller Rockers.
RPM Air Gap intake
Aluminum valve covers
Demon 750 (manual secondaries)
Moroso 7 qt oil pan
The motor is turn key minus pulleys, water pump and distributor with about 1200 cruising miles on it. This is a really nice motor and the only reason I am willing to part with it is because I have been presented with another motor that is much larger for cheap. Again I am only looking for what you guys would ask for if you were in my shoes. Thanks in advance for you input!
Steel crank 3.76
RPM Air Gap intake
Moroso 7 qt oil pan
