Someone with a big block please help me with your suggestions on a camshaft. 454,closed chamber heads with sone port work, 9.5comp, th700, 3:42 rear end, all accessories including ac. Weekend car, thinking of something not to radical like 218-228 @50 500-500? What do you guys suggest or have in your combination?
One of the most overlooked factors in cam selection is the toqure converter stall. I like to have my cams come into there power band 300-500 RPM before stall. If after it will be a dog as you are not getting any toqure muliplication. There are many other factors involved but this is one of the most basic.
NOTE; many cars are over camed because guys think they are launching 2400 lbs. instead of 3800 lbs. If your car is full dress then work on bottom end it's no use going to 7000 rpm if you have already lost the race on the launch.
Harley
Given what Harley said, your specs look OK. My 427 was run with a 2600 stall, in a Camaro ( 3150 lbs) and 3.73 ( T400 ). It has a Crane (solid ) with 238/248 @0.050 and it was just enough stall. Just. If you have the stock converter in you might want to stay below around. But .550 lift would be OK. My crane is a dual pattern and with the more shrouded CC heads ( vs. open)I would also consider a dual pattern cam.
Sorry forgot to mention the car is in full dress and is a 72 convertable. The stall will be around 1,500. The cam I mentioned above is a dual pattern ground on 114 lobe centers. Any similar combos out there? Thanks for the help
G
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 11-209-3
GRIND NUMBER: CB 275DEH-10
ENGINE: CHEV BIG BLK 396-454
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .507 .531
.006 TAPPET LIFT 275 283
VALVE TIMING OPEN CLOSE
AT .006 INT 32 BTDC 63 ABDC
EXH 76 BBDC 27 ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 219 229
LOBE LIFT .2980 .3124
LOBE SEPARATION 110
THIS CAM SHOULD USE SPRING # 911-16
from
www.compcams.com
Wally
Gold #67
67 malibu
