396 4 speed Muncie 12 Bolt Posi
I’ve put on about 1,000 miles since I bought the car. Everything was fine until the last several rides when I started noticing a vibration at 50-60mph. I have made NO changes to the drive train so something’s definitely wearing out.
I can feel the vibration in the shifter but it’s definitely coming from the rear somewhere… kind of feels like the rear end is driving down a worn down rumble strip. There’s absolutely no vibration at all up front - nothing at all on the steering wheel.
After reading the posts here on this subject, here’s what I’ve done so far:
· Rear tires rebalanced – no change.
· Swapped the front and rear tires – no change and the vibration did not move to the front.
· Replaced u-joints – no change and didn’t notice any slop at the pinion bearing or tail house bushing
· No evidence the driveshaft threw a weight – is it possible for the driveshaft to get torqued out of balance?
I think I’m pretty much down to the axle. I don’t think I bent it – not sure if this matters but it’s got traction bars so I’m guessing it would be pretty hard to bend the axle with those things bolted on. I don't drive it that hard and don't take it to the strip.
I’m lucky to have a very good local shop but before I bring it in is there anything else I could check? I’d hate to take it in only to find I overlooked something obvious.
Thanks in advance for the help!
