1 - 2 of 2 Posts
I am finishing off a crate motor swap in my 65 chevelle and need a power source for the HEI distributor that supplies 12 volts when cranking and when running. I removed the old resistor wire for the points distributor and connected a 12 gauge wire in it's place on the harness. I don't have a battery connected to test this, would that source supply battery voltage both when cranking and when running? If not, where can I get a power source for the distributor?
65 Danube Blue MALIBU 4 door wagon, 350/330hp crate with 700R4, Factory air, Factory am/fm stereo.
YES it will, no problem.
Joel
T/C#980 1968 SS396 CHEVELLE
If at first you don't succeed, skydiving is not for you.....
1 - 2 of 2 Posts
