I'm just finishing hooking up the new engine in my 69 Chevelle. I'm installing an HEI and have an issue. I thought that if I ran a new power wire off the fuse block that I would be in business. Turns out the engine will only run the second I take my fingers off the switch (and it goes from the start position to the run position)
It makes sense now - I realized my aftermarket radio looses juice while the key is in the 'start' position as well...
So whats the fix? Is the ignition switch not supposed to cut power to the fuse block when its in the start position? It makes sense that it would, to apply full power to the starter... So how are the rest of you guys applying power to the HEI? I considered hooking up the circuit that feeds the points full current when the start is engaged but I've read several places to tape that circuit off and don't use it!
Thanks for your help!
David
David
