Here are the part numbers for the HEI terminal and connector. These are the wire ends that clip onto the cap. Available from your GM parts dept.
If you're hooking up a tachometer wire to the dist cap, you need these parts.
The brown plastic connector locks onto the cap to keep the wire from falling off. The brass terminal clips into the plastic connector and fits the spade in the cap perfectly. I don't think these are available anywhere but the GM dealer.
Don't use those solderless connectors. This is better.
The terminal comes in a pack of 10 and the connector comes in a pack of 5.
terminal
part # 12033824
Gr. # 8.965
Connector
part # 08917052
Gr. # 2.170
These are not cheap.
If you need singles, pm me.
terminal
part # 12033824
Gr. # 8.965
Connector
part # 08917052
Gr. # 2.170
