I am going to change from my points distributer to HEI. Never done this before. I could use some help on the proper proceedure.
71 SS Chevelle
454/495
Muncie M-21 4 Speed
12 Bolt 4:11 Posi
Acting Like it Wasn't Me
I did the same thing on my 69. I bought the following items:
Junkyard HEI (with the 12V supply connector)
Accel HEI Supercoil
Accel Cap and rotor
I pulled the resitance wire from the juntion block and carefully removed it from the spade connector. I them soldered a 12 gauge wire to the spade and the HEI connector. Replace the wire in the junction block, Drop in the HEI, and hook it up.
If you look in Wes Vanns Tech ref section he goes over an HEI conversion.
Plain Jane 69
Discussion Starter #3
Thanks for the info. I was unable to find a "tech ref area for wes vanns (or vann). I must be doing something wrong. #^(#
Discussion Starter #5
Thanks John! That is perfect.
71 SS Chevelle
468 cid
Muncie M-21 4 Speed
12 Bolt 4:11 Posi
