I am switching to an HEI distributor. It is in the block.. All I need to do is run the hot wire from the key side of the fuse box. My question is...Has someone else done this very thing a clean way. I don't see a "professional" way to do this and make it look good. I will probably just splice onto one of the connectors behind the fuse box. My other question is. with the old distributor off, where does the wire go that originally led to the tach? Also what exactly is the fabric shielded wire that lead to the same terminal as the tach wire? (guessing starter..)
That should be a good start.
