Hey guys,
I had some aluminum looking Proform gaskets on my 489 with Heddman Hedders and I had a lot of leaks going on. I decided to replace them with some copper Mr. Gasket hedder gaskets. When I removed the Pro Forms I noticed that in a lot of the corners where the leaks were there wasn't even gasket material (or not much) according to the contact pattern. So I replaced them and as I was tightening the bolts this is what I saw (bolts are pretty much torqued)
It appears that there is quite a space between the hedder flange and the head. Is this normal? I know that the rings are raised on the flange where the head meets the port but the gap seemed excessive. I haven't fired it yet because I still have to tackle the other side, and I wasnt sure if i should be ordering some better gaskets. What do you guys think? Any advice on a better set of gaskets (if that is the problem)? I guess I am just concerned because the last gaskets didnt have that gap, atleast not that I could see....
Thanks in advance,
Brian
Thanks in advance,
Brian
