if you remember my heater fan switch was heating to the point where you would burn your finger on the switch once it was turned on. I had a new switch, installed it and sure as [email protected]# the old one was burned, the phenolic back panel was dark brown, and the metal housing had signs of heat/fire expulsion around the sides. what could cause this????? I did have a window leak that I have fixed, but the switch is so far away from the path of the water I don't think that was it. I am concerned because I think the new switch might be building up heat too. I don't know why? I am the second owner of this car. I bought it from a little old man so I know no wires were cut, and every gauge I added went right to the fuse block with a fuse, so I am fairly certain there are no open wires or cut and chafed wires. any help would be great, thank's in advance, mike and the car is a 70 el camino by the way
