I have a 69 Chevelle with A\C and the heater motor sounds like it is going to explode. The motor works fine through all speeds but it sounds like the fan blades are falling off of the shaft. I have heard that you need to remove the fender to get at it, is this true? And also in most cases do you have to replace the whole assembly or just the "squirrel cage". Your help as always will be appreciated.....Scott
