1 - 10 of 10 Posts
Guys, I'm swapping a 350 into my 64 C10 pickup. I have a short water pump, and all of the associated brackets and pulleys are installed. The only problem I have is with the heater hoses. The truck has two hoses, one 3/4" and one 5/8". The 5/8" hose I have connected to a fitting on the intake manifold, no problem. The 3/4" hose, however, is supposed to go to the water pump as far as I know. The only fitting I can find with a nipple big enough for a 3/4" hose won't screw into the water pump. The threads are right, but the threaded hole in the pump is so close to the casting of the pump that you can only screw in about two threads before the hex portion of the fitting bottoms out against the pump casting. Is there some special sort of fitting required for a short water pump? I feel like I must be missing something.
On mine,came that way so left it.Has a regular pipe thread and about an inch of nontapped pipe then thread end.With the hose attached to the end.More of a 2" or so pipe male union.Doesn't have way to put a wrench on.Would have to put union in vice and tighten with the pump.Way I put back on.
Hmmm...maybe there is a special fitting for short water pumps that has pipe threads, then a couple of inches of pipe, then the hex head, so it would be spaced out from the pump.
Looked like something you could get at homedepot or plumbing place for waterheater or something.Haven't seen it leak.Hose would attach to threads instead of ribbed area.And then hose clamp.
Looked to be just a 3 or 4" piece of pipe threaded on each end.If your pump is allready on,could tighten with strap wrench or use a double nut on end to tighten,where one nut locks the other down.Then use regular wrench on end nut.
I have grown to hate the early small block accesories set up for reasons such as this. Setting up headers can be a challenge too. Most small block short sytle water pumps have a fitting at the top. A simple fix can be made with cast iron plumbing parts.
Use a 3/4" threaded adapter (threads at both sides) and install this piece into the top outlet. Then install a 3/4" x 1/2" 90 degree elbow to the adapter and finish with a 1/2" piece that is 2 1/2" long and exiting to the passenger side.
Mount the elbow flush with the water pump and paint to match (requires trimming the 3/4" adapter to fit). The 5/8" hose will slide over the 1/2" pipe threaded section and exit cleanly to the passenger side where the hose is routed to.
All these pieces can be found at a hardware store for about $2.50. Not factory, but a neat install. Some may call this ******* but it is a cheap fix. If you want show quality, these parts are available in stainless steel from a few differant companies found on the internet.
Good Luck!! :D
The original piece had the pipe thread, 2 or 3 inches of straight pipe, then the nipple.
Maybe just put the hose on a 3" hardware store pipe?
On the subject of short water pump brackets, if you have accessory holes in the front of your heads, the alternator bracket for a late 70's thru-82 vette works GREAT! There are 2, one cast iron, one alluminum, the alluminum one will take a polish pretty well. They can be found at corvettecentral.com, or if you can dig up the part # gmpartsdirect has em for half as much.
1 - 10 of 10 Posts
