1966 El Camino 350/370HP 5 speed TKX 3.31 rear.1967 Chevelle 454/430HP Th400 w/Gear Vender 3.73 rear
I do not believe there would be an issue but thought I'd get some opinions on routing the 3/4 line from the stock heater core (66 El Camino) to the intake manifold and the 5/8 line to the water pump. This will be backwards from how the factory installed the lines, but would improve the appearance under the hood. There is no closing valve in the system so the water is constantly circulating. With the flow circulating constantly I see no down side to do this but wish to be sure.
