Headliner Install??
556 2
Can anyone give any tips on installing a new headliner or should i just hire it done?? I think i can probably do it myself but i dunno, what type of adhesive should be used??
Lifetime Founding Member
Make sure you have plenty of time and don't get in a hurry. Much easier with the windshield and rear window out. Be sure the same bows go back in the same holes. Use HD spring type paper clips to temporarily clip it in place all around. Go around several times, working it into postion before glueing. Get the front to rear tight before sides. Use only the headliner glue like what's available from Chevelle parts places. You'll need two cans. Contact cement doesn't work well (too stringy).
