Is there a difference between a 70 headlight switch and a 71 ? I have a 71 and when I removed it I compared it to the new one (that is supposed to be a 70) it has one more spade terminal at position 7 (I think).
Could I just use a Dremel and cut this terminal off and use the newer switch ? There is no female connector on the wiring harness connector for it.
Thanks !
Tom
I don't see any wiring difference on the connectors between those 2 years. Same wires in the same places so the switch should work. Almost think the switch is not from a 70. You have extra fuses on hand...don't you?
