The headlights and front parking lights do not work on my '65 Chevelle 300 convertible. The tail lights and the turn signals work fine. Here's what I have checked:
1. The headlights are plugged in.
2. I checked the fuse panel and studied the wiring diagram. I did not find a fuse anywhere in the circuit. Did I miss it?
3. The wires are tight on the headlight switch.
4. The headlight dimmer switch is messed up. It does not click when I step on it.
5. I checked the 14 B/LBL wire at the dimmer switch with a volt meter. From the wiring diagram, this wire appears to be wire which goes from the headlight switch to the headlights. With the headlight switch in the on position, there is no power to this wire. On the plug in clip for the headlight dimmer, the plastic clip is melted off around the 14 B/LBL wire. It's hard to tell whether the melting is recent or old. The insulation on 14 B/LBL wire is otherwise okay.
Is it possible that the dimmer switch went bad and blew the headlight switch? Since the headlight circuit does not appear to be fuse protected, it is possible that the headlight switch could blow before the wire burned if there is a dead short.
I don't know much about electrical. So any advice, no matter how obvious, could help.
