ok i now have the 441 heads i was getting, the problem is they both have 2.02 1.6 valves but 1 head the intake valves sit lower than the exhaust (like they should) and the other head they are even (this is looking at the chamber. can this work correctly? they are different heads but same 441's could they be done correctly but maybe one more deep than the other? also on the springs, when the stock rotators are used doesn't that change the spring height?? just need some input here i tried a 194 valve in the 202 spots but they seem to sit too far down even in the head that the valves stick up even. and also wondering if this could change compression? thanks jk
members.aol.com/jnkb2cool/chevelle9.jpg members.aol.com/jnkb2cool/350.jpg
John Krenn
1970 malibu SS look-a-like well kinda
307/200-4r (soon to be 355)
Ft.Worth, Tx
John Krenn
Ft.Worth, Tx
