I was looking into a rear coil over conversion for the Chevelle. I want to keep the upper and lower control arms ( but upgrad to Currie arms) and rear swaybar mounts... but eliminate the stock coils and shocks. I dont want to tub the car or use a Furd 9".... I may upgrade my open 10 bot for an all new Moser 12bolt with posi..... I like the idea of adjustable ride height and a million spring choices.... I already have the AFX spindles w/ C6 brakes up front and will be doing a coil over conversion with Global West LCAs ... I will have Tyler from ATS here in Vegas help will the suspension mods....
Any thoughts or has someone done this alreay? Looking for suggestions on mounting points for the coilovers. I dont think I can use the stock mounting points.... I need to crawl under the car and look to see if there is room for a seperate crossmember for coilovers.... Or any clearance issues... gas tank or anything like that....
