The wire colors and connections on the bulkhead are the same. You will likely need to change the park/signal light connectors I think they are different. You may also find that not all component locations are the same 66 to 67. I’ve never owned a 66 and haven’t spent much time under the hood of one. If buying a new 66 harness is out then adapt the 67.
