Hello,
I have a problem with hard pedal and no boost on my breaks. It used to work just fine, but then, suddenly, when I pressed break pedal, started up engine, I heard some noise (something breaking, like balloon poping in from of the car) and there was no boost anymore. I need to press pedal very hard to break now.
Why it is not a vacuum problem:
- I did use two different valves (one brand new)
- I did change the hose to new one
- I did check with vacuum meter - 12" (0.04MPa)
- I did put long hose and connected my vacuum to other car (Capriece with almost identical break system) - everything is fine
- I did put long hose to other car, and connected to my booster - no boost
Why it is not servo problem:
- I used another, brand new servo - no boost
- I used same new servo in another car - working fine
Why it is not MC:
- I used MC from another car - no boost.
So I used my vacuum in other car, other car's vacuum in mine, I have used two different servos (one of them checked in another car), I used two different MCs in all possible combinations and... no effect.
Any clues? I've read something about stuck wheel cylinders, but my friend mechanic says it gives totally different effect.
Why it is not MC:
