pretty clean single sensor?I’m using a wide band from Speedhut. Lowest gauge on the right side of the dash. I have Speedhut in two of my cars. Seem to work well and are customizable if you’d prefer.
Cheers.
Yep single sensor in the left side exhaust.pretty clean single sensor?
yessir it’s on before I start it 🙂 just another part of the ritual now lolYou put it on a rocker switch? Just making sure you don't have it shut off while the car is running, think this can lead to a fouled sensor.
It stays on 24/7 w a nice blue light. I usually shut my car off w the dead switch off the trunkYou put it on a rocker switch? Just making sure you don't have it shut off while the car is running, think this can lead to a fouled sensor.
Might need to up/tune/tighten the accelerator pump cam to get rid of that lean spike when you hit the throttle. WOT should be around 12.5 for performance. LS tuners usually shoot for 12.9 but we're dealing with injector per cylinder and matched intake runners/combustion chambers. With the inconsistencies of sbc/bbc intake runners and their distribution of fuel you need to stay richer in order to avoid burning a cylinder up. I know Engine Masters on Motortrend have done some cylinder to cylinder distribution testing on the dyno as well as Richard Holdener on youtube.Kk so what kind of and numbers would you be looking for I’m 13.5 ish (bounces around) at idle and when I stomp it Itl grab up to 16 for a sec which I’m guessing cuz of the extra air. Wot is between 14 and 12 I’m running a 770 sa w vac secondaries and plain spring. 70s up fron and 72s in the rear my fuel pressure is at 5.5 at idle although I can see my gauge from inside the car so there’s no telling where it’s at at wot what do u guys think .... on the right track should I roll purple spring then try yellow first then maybe go up 2 jet sizes on primary and secondary?? I feel like I may be running a tad lean here..... my plugs look brand new that’s what’s tripping me out
. You're close though.up/tune/tighten the accelerator pump cam to get rid of that lean spike when you hit the throttle
