ok here's what im rebuilding 350 30 over,kb pistons 8.9-1cr w/76cc smog heads 1.94/1.5, comp270h cam wich is 224dir.at .050, RPM intake headers and edelbrok 600cfm carb, this is what i have currently
and what is a 355 anyway??
A .030 over 350 is close to 355 cid., hence the name 355.That will be a good running engine, have a buddy with the same combo, but a 4 spd. car,he has #492 straight plug heads though.They flow a little better than yours.
Discussion Starter #3
come on guys someone has to have this combo, what are you getting for hp. should i buy another set of heads?? if so i will have to wait ($$$$)
250-260 h.p.
Harley
69 461 El Camino Nitrous Model, 69 Chevelle coupe
70 El Camino,71 SS Camaro
75 L-82 Corvette,71 Gremlin X
Kerrville,Tx.
Actually, you might have a little more then 250-260. This is about right without headers, with headers and a good 2.25"-2.50" exhaust, probably closer to 300hp.
Pat Kelley
66 El Camino, daily driver
67 El Camino, STRIP/street
