I'm currently replacing my original wheel on my '65 wagon with a new Grant unit. Does anyone know if the turn signal switch needs to be taken off of the factory hub and bolted onto the replacement hub provided in the kit? Or does the replacement hub provided go on over the existing hub/turn signal switch. The instructions are not very clear, and the plunger for the horn on the factory switch does not line up with the parts provided in the adaptor kit. I even thought they had given me the wrong adaptor kit but verified it on the grant website. I'm either stuck or missing something very obvious.
What I remember is that you don't need to worry about the turn signal switch, the hub adapter fits above that. Check to make sure it's right side up, I seem to remember that it looked like it could go either way. I now have a Momo wheel and I think it has a brass contact ring on the adapter with a pigtail to hook to the horn button.
