I removed the steering column when I pulled the dash down to fix some electrical problems. I had trashed the rag joint in the process so I got a new one. When I put everything back together the steering wheel is now upside down (the three spokes are on top). The rag joint is idiot proof so it only goes on one way on the steering box and the shaft is the same way(2 diff. size bolts). My question is can I pull the sterring wheel and spin it so the spokes on on the bottom? I did nothing with the sterring box to take it off center.(it's a 67)
Thanks Tom
Tom
Belleville, IL
67SS Yellow right now
Member #409
Thanks Tom
Tom
Belleville, IL
Member #409
