Lemmons has two types of headers: Racing, and Pro Touring. Their racing headers, (which is what the OP has) have two primary tubes on the drivers side, and two tubes on the passenger side going outside the frame rails and invading the wheel wells. And their Pro Touring headers keep all the primary tubes inside the frame rails. The largest primary tube size on the Pro Touring headers is 2 1/8" diameter, and Dan Lemmons will give you the option to have slip-on collectors and individual primary tubes with their Pro Touring headers if you so choose, just like their Racing headers have. Having individual tubes with the slip-on collectors makes installation a whole lot easier, and in many cases, the engine will not even need to be raised off of the motor mount.
According the installation instructions, there isn't any necessary sequence of the individual primary tubes for the Pro Tour headers, but for the Racing headers like the OP has, it says the following;
"Driver side: install #1 then #7 from the bottom and snug the header bolts, but don’t tighten. Then install #3 and #5 these are the tubes around the frame, snug the bolts. Now install the collector and go back and tighten all the header bolts.
Passenger side: install #2 and #4 from below with the starter in place, then #6 and #8 these tubes go around the frame, then install the collector. If there is such a thing as an easy header to install this is it.
Refer to our header installation tip’s page for additional information."
Dan Lemons will also impression stamp the cylinder number on the flange of each primary tube if the customers so desires, (before the ceramic coating of course) to avoid any confusion as to which primary tube goes to which cylinder during installation. Dan Lemmons is a great guy to work with, and the guy knows his business very well. He will ask you a series of questions about your car and the accessories, and about what cylinder heads you have, and just by knowing what cylinder heads you have, he knows if they have raised exhaust ports, and if so, he also knows exactly how much they're raised. Calling Dan and speaking with him is nothing like speaking to so called "tech" people who man the telephone lines at most aftermarket businesses. Dan is hands-on and he takes part in your header build.
To The OP: with ceramic coated headers, the instructions also specify that you need to either use a piece of 80 grit sand paper by hand, or a #40 flapper wheel with a die grinder or high speed drill motor to scuff off most of the ceramic coating on the inside of the beginning of the slip-on tube area, and also use Permatex Copper anti-seize on them to aid installation, and disassembly, and to prevent corrosion. I asked him if the Permatex Nickel anti-seize can be used as an alternative, since that is rated to 1,000 degrees hotter than the copper anti-seize is, (2,400 F.) and he said the he didn't see why not. Although I'm sure that either one would be fine since the collectors aren't going to get as hot as the beginning of the primary tubes near the flanges.
