My uncle gave me a new GMPP 454 block (Gen V1). It was one he bought from Summit and then found another block he decided to use for a build so he gave it to me!!! Is this even a good block to start with or should I look for another?
I am going to do my FIRST (God help me!!!) build as I thought it would be fun and educational at the same time. I already have a GMPP 454HO in my 71 Chevelle but would like to build one with a little more HP and these GMPP crates seem to burn oil due to the rings they use (mine burn just a little but a little is still too much!). I assume these are the same blocks in these engines.
So, for those who have been down this road, give me a recipe for a kick-ass 500hp+ streetable setup that can easily hit low 12's or even a high 11 if I'm lucky (heads, pistons, crank, cam, valves, etc.....). Kinda of a buyers list if you have one (summit and jegs are where i get most of my parts but i can buy elsewhere)
I have a local engine/race machine shop that can do and machine/porting work i need done. Also, even though this is a new block, what machine work would you have done prior to starting on this project as the complete crate engines cylinders walls are sometimes questionable.
Any help will be greatly appreciated,
ASO544
ASO544
