1 - 2 of 2 Posts
Hey Guys,
This not related to a Chevelle but hope you can help me out
My 34 Ford has a GM power steering pump and a Mustang II rack and pinion
Had to drain the fluid to fix a leak what type of fluid should I put back in it the fluid that came out looked to be a red color.
Bought some Lucas P/S fluid but not sure if it damage the rack and pinion was thinking Ford systems used type F fluid
Thanks for any info
Administrator
All manufacturers are using power steering fluid, the only exception is Honda that use a different fluid.
1 - 2 of 2 Posts
