1 - 20 of 26 Posts
I thought it might be helpful if we had a comprehensive list of parts still offered by GM.
I'll start with one . . . you guys do the rest.
1) 3989479 71-72 bowtie center cap for SS wheels.
Next??
BTW I just ordered some parts from a dealership in Virginia that will cut you great prices on GM parts.
Give him a call (Gregg) and tell him Tim From Utah told you about him.
L8R
Mr. D
72 454 El Camino
68 RS/SS Camaro
73 RS/LT/Z28 Camaro
99 Firebird TA WS-6 A4 Color: Pewter
1995 LT-1 Caprice
1976 Jaguar XJ12L Chevy 350 converted . . for sale.
An all GM site http://www.gmforums.com
What a GREAT IDEA ! I have been "collecting" part numbers for quite a while now, here are a few:
'68-'69,etc. Door Sill Plates 7753966 (rh) & 7753967 (lh)
'70 Fan Shroud BB 396/454 6261914 (need to verify application)
'70 Shroud, Steering Wheel, Black 3972735
'70-'72 Exhaust Tips, Chrome, 3956756
***TIP: check your part numbers at www.gmpartsdirect.com
Kent
'68 Malibu ZZ502/502
Here is his #.
1-800-277-0917.
Tell him Tim from Utah told you about him.
tell him to cut you a deal on including shipping and tax if possible.
Hey MrD
would that cap be the same as a 1970 Z/28 wheel cap ?
Nate
Current collection:
1. 1969 Chevelle S/W SS396 TH400 12 bolt 3:31 Posi PS PDB AC Dual action PW gate Blue/Blk int
2. 1969 Chevelle Malibu 2 dr hdtp All #'s match L48 350/300 TH350 12 bolt 2:56 PS PDB AC Tilt Parchment/butternut (193,000 mi. never apart !) 98% orig car
3. 1969 Chevelle Malibu Convert Light green/Blk int 350 TH350 10 bolt PS PDB AC Buckets/console Pwr top 87,000 orig mi.
4. 1969 El Camino SS396 Cortez/Blk buckets PS PDB PW No-AC TH400 12 bolt 3:31
5. 1969 Nova SS 350/300 M20 3:31 Posi Red/Red Buckets No console PS PDB No-AC 88,000 orig mi.
6. 1970 Camaro RS Z/22 #'s match 350/TH350 PS PDB AC Shadow gray/blk int Orig AM/FM
7. 1971 2 dr Lemans Sport 350/TH350 10 bolt 3:31 PS PDB AC PW buckets (sold my 69 GTO, went into Poncho withdrawals and had to buy this one !).
Nate
Yes it is the same for 70-74 Z28s.
another camaro part #
3990470 70-73 RS front spoiler.
The standard is also still available. Don't have the part # here though.
Guys
LIST # you have ALREADY researched and know are available here. That will save guys tons of time doing searches for parts that may or may not still be available at those websites.
Mr. D
72 454 El Camino
68 RS/SS Camaro
73 RS/LT/Z28 Camaro
1995 LT-1 Caprice
I've mentioned this before but BEWARE of superseding part numbers. These parts will do the job alright but they probably are visually different. Example. Instead of a cast combination valve you get a brass one from later models. The big block Chevelles without air got a pretty straight upper rad hose. The one you get now is actually from a full size chev with a 350 and has a big dog leg.
If you have a dedicated parts man, it is surprising just how much GM still has stashed away. Up until a couple of years ago they were still making '69 quarters periodically.
This is a good one most guys don't even know exists. It's the super heavy-duty posi springs good for about 400 lbs of preload.
Part number #488332. The good-guy price is $8.77 each.
70isfine
Post the part #. I need one for my 68.
LT-1 350 aluminum valve covers
474208 Left or right?
474207 the other side.
can you beat $180 shipped to my door?
3829387 Deep groove alt. pulley
3899660 Deep groove crank pulley
3770245 Deep groove w/p pulley
10147945 Q-Jet insulator Assembly
14015389 Alt. bracket lower
14015434 Alt. bracket upper
394926 7/8 rear sway bar
Flow Chevrolet/GM Parts Direct has pretty good prices
"Astronauts get all the chicks. It says here, they get all the Tang they want" Kelso from That 70's Show
Richard Dorrough
Tulsa, Ok
'70 Nomad (CHVELLE)
ACES # 789
TC # 453
Discussion Starter · #14 ·
Kent
thanks for that #.
TTT
more #s please
Thanks for all the #s so far. I may look at those pulleys.
Mr. D
72 454 El Camino
68 RS/SS Camaro
73 RS/LT/Z28 Camaro
1995 LT-1 Caprice
Here's a few...
Rally wheel caps (without the flat base- just the cap) 3925805
72 Chevelle LH turn signal lens 5965269
68-72 Window cranks 20037597
68-72 door handles (inside) 7743520 7743521
70-2 quarter window chrome mld. 8734082(R)
8734083 (L)
70-2 (R) 1/4 marker bezel 3972900
68-72 Sill plates 7753966 (R) 7753967 (L)
72 SS Grille emblem 6272090
70-2 "Cowl" emblem 3968567
70-2 "Induction" emblem 3968568
70-2 Exterior door handles 5719142 & 5719143
72 fuel sender 6428035
71-2 SS wheel trim rings 3984524
71-2 SS wheel centers 3989479
70-2 Hood hinges 3976675 (L) 3976676 (R)
70-2 hood springs 386480
396-454 plug wires 12043784
70 Taillight lens 5964288 (R) 5964287 (L)
70 BB fan shroud 6261914
454 oil pan 14091488
70 rear valence 3962322
70 grille 3956117
69-72 Interior SS door emblems 9817279
70-72 cowl inducted rear hood mldg. 3968501
69 outside door handles 5719142 5719143
69 washer jar 3840083
69 SS wheel center 3956770
69 hood mld. rear 3936293
69 wheel opening moldings 3936289 (LF)
3936290 (RF)
8700947 (LR)
8700946 (RR)
I'm relatively certain these are all good numbers as of last month or so. Good luck!
72 SS coupe clone & 68 ragtop, 69 ragtop. www.NoNecksChevelle.com
Discussion Starter · #18 ·
nokneck
great list.
I just recieved my GM center caps for my 72 SS wheels and they are not the same as originals .. . the blue is not reflective like the originals.
That sucks big time.
I guess they are ok for a driver but not really correct.
Mr. D
72 454 El Camino
68 RS/SS Camaro
73 RS/LT/Z28 Camaro
1995 LT-1 Caprice
I know that some of the stuff that is available thru GM is definitely different from the original GM issue stuff, but, it's still generally better than no=name Tawain stuff. For instance the sill plates from GM are different in that the originals had the "Fisher" tad riveted on. The new ones are not.
1 - 20 of 26 Posts
