Thinking in my non prepped 3.31 geared car I should be good for low 11's with this motor...I remember a few TCers (T-Bone) running this motor and running deep into the 10's in a well prepped 68 Chevelle..
More likely to get a big MPH, than a low ET. Without suspension work you will likely kill a lot of ET the first few hundred feet of the track.
Steve R
More like similar results...JMHO, unless the motor you have needs a thorough going over, (nothing against buying a VTP engine) I think you are just trading dollars. Pull the heads ( IIRC, you have 215's with larger valves?), send them out for a pro porting and do a cam swap to match the flow data. Same result, a lot less money.
Joe, your pile went 11.50s on a 540. My 402 LSx went 9.40s on a 200 shot. My neighbor has two rabbits. I think you are giving bad advice.JMHO, unless the motor you have needs a thorough going over, (nothing against buying a VTP engine) I think you are just trading dollars. Pull the heads ( IIRC, you have 215's with larger valves?), send them out for a pro porting and do a cam swap to match the flow data. Same result, a lot less money.
thanks BillChris,
Why would you want to run quick enough to require a roll bar?? Your car is WAY too nice for that crap...![]()
This is a joke, right? Good one! lJMHO, unless the motor you have needs a thorough going over, (nothing against buying a VTP engine) I think you are just trading dollars. Pull the heads ( IIRC, you have 215's with larger valves?), send them out for a pro porting and do a cam swap to match the flow data. Same result, a lot less money.
What is the joke? You are saying you couldn't port his current set of heads to deliver the flow rates and performance provided by VTP?This is a joke, right? Good one! l![]()
You just don't get it. Unforetunately Andy, I never got to run at a track that allowed you to run a car to it's potential without a roll cage. Don't know what Chris faces, but would guess the few remaining tracks he might have access to will be just as strict. I kinda think 11.50 / 125 mph in a 4100# car was getting it done.Joe, your pile went 11.50s on a 540. My 402 LSx went 9.40s on a 200 shot. My neighbor has two rabbits. I think you are giving bad advice.
Dollar for dollar, it is very hard to beat one of Marks' mules with a Straub cam. As a buisness owner and a certified gear head, no body is getting rich at VTP. They are just going fast.
:thumbsup:I kinda think 11.50 / 125 mph in a 4100# car was getting it done.
i'm still trying for 11.50 with a lighter 3995# car!i kinda think 11.50 / 125 mph in a 4100# car was getting it done.
