1970 Chevelle Vortecpro 496, Hotchkis TVS Suspension, TH400, Factory 12 bolt/strange axles
So ive been working on repairing some minor rear end damage on my 70.
it was a good time to replace lower quarter skins and outer wheel wells so i did that. seam sealed all joints and overlaps of sheet metal
i also removed and repaired some rust around the rear window channel and installed water drains in the corners.
i removed the doors and went all the way around the jambs of the doors and the cabin and sanded down to bear metal
rebuild the door hinges
installed all new body bushings
i removed all interior except for the head liner and dash
i removed all of the glass except the wind shield that they said they would take out.
blasted and re painted core support
purchased new AMD fenders and wheel wells for the front (still need to get these fitted)
got all new front end hardware to put everything together.
is there anything else i should do before i send it to the body shop. they asked me not to do any filler work so that they could warranty the paint job so as far as the outside im leaving it alone. I mainly wanted to get the car stripped down and all the crappy door jamb and rust repair work done so that i dont get hit with costly body shop extras while its there. i plan to have all of the body sheet metal assembled and bring it to them so they can see that everything fits and lines up, even though they will have to break it down to spray the jambs. i have read a lot about how much work it can be to get the aftermarket fenders to line up good. what more should i do or not do?
