I am having a strange issue. The ign terminal at fuse box, where i am triggering my holley ecu off, is getting 5v when key is in acc position. I am also getting a 5v reading at the oil psi and temp sender wires (dummy light dash) when in acc position, and 5v at the pink wire from ignition switch plug. If i remove the "gauge" fuse, i no longer get 5v at the ign terminal when in acc position.
Any ideas what could be backfeeding into the ignition circuit when in accessory mode? Id like to be able to play the radio in accessory mode, however its causing my ecu to turn on since its seeing voltage.
