if the alternator is still giving a good charge, and the fan belt it not loose, why does the light stay on?
Gold Founding Member
If you're not having a problem with the battery going down a new voltage regulator probably won't help the light go out but I suppose it's worth a try.
Grandson's nova has had the light on for a few years and everything else has always worked fine.
Moving thread to electrical & wiring forum.
On my '67 had a DIM alt. lamp. thought it was the regulator. changed it, light still was on dimly. Found I had a blown fuse, can't remember which on though.
Generator light on dimly is usually the diode trio.
If the light is on--there's something wrong. Period.
Could be a bad alternator/regulator, or a grounded wire to the field connector.
