1 - 10 of 10 Posts
Yesterday I was looking at 2 Gen VI blocks at the same location. One had the timing cover pattern for the cast timing cover, the other had the old stamped steel pattern. I thought all VI's had cast aluminum cover.
Some very late production Gen V blocks were marked as Gen VI but still retained the early 10 bolt front cover .
TOM
If using a HFT cam with the cast cover what do you do for cam end play?
Nothing,,,,,,
You do not need to control cam end play on a flat tappet of any kind the lobe taper pulls it against the block
do these blocks use the step nose cams???
Yes they do but.......
You can use either cam in all BBC's they all have at a minimum the bosses for the thrust plate bolts & the majority will be drilled & tapped
Almost all early blocks were drilled for the factory gear drive thrust plate so the "step nose" is a drop in with the correct timing set
what i was getting at was more that the gen-v was equipped to use a step nose cam;
but are there step nose flat tappet cams??
^ no need. The retainer sets endplay and prevents the cam from walking forward.
Flat tappet cams walk rearward by design, there's no reason to restrict their movement forward.
1 - 10 of 10 Posts
