Any one running a XPipe with a gear vendors?
Im trying to mock mine up and it looks like the my xpipe will be a problem
G
No doubt!! I think the numbers I've heard on these is the unit is about the size of a 3 pound coffee can and it adds about 14 inches on the overall length of the trans.
Mark, my gv yoke is about 3/4" away from center of xpipe and i still have to modify and lower my crossmember mount 3/4"
if i move the xpipe closer towards the front of the car it will be to close the the sump on gv
Lower the mount on the crossmember, then raise the whole crossmember. The mount needs to be changed so the GV doesn't hit the crossmember - but when you do that you'll have plenty of room between the GV and the top of the trans tunnel to raise it up (at least I did).
If you can figure out a different way to alter the crossmember, I'd do that - but it was pretty easy for me to add some washers on either end of the crossmember to raise it up.
Hope that made at least SOME sense... hard to describe.
Also - my mufflers might hang a little lower than yours, too....
