1 - 2 of 2 Posts
Hello all,
I have searched the forum and can't seem to find an answer. I have a 12 bolt in a car I purchased. It has a spool and a gear set with the following sets of numbers:
Richmond
80-0629-1
05 8620
I can't seem to find what series or ratio this is.
Thanks in advance for your help!
Jeff
Lifetime Founding Member
Count the ring gear and pinion gear teeth. Divide the number of ring gear teeth by the number of pinion gear teeth and the result is the ratio.
1 - 2 of 2 Posts
