1 - 14 of 14 Posts
Gang getting the end here of collecting all my parts. I should have the engine back from the machine shop in a few weeks and so weill be taking days off of work to put the engine/tranny in the car and fire it up. One of the last parts i am need to pickup is a Gear Reduction starter. So naturally there is a handful of starters. I am looking at Powermaster's but more concerned on engine fitment when ordering online. So what is everyone thoughts.
Engine - 454
1981 block
Out of a ruck/motorhome
running stock flywheel
Will have 10.1 Compression
Reactions: 67-468
I would have a stock starter built up by somebody who knows how to build the hi torque starter..
My preference is a 19302919 gm performance starter. Can be had on ebay for a bit over a couple hundred. It's a blem but because it has some paint on the housing. You won't be unhappy.
ebay item #
271709331163
Get a cheapy from a late 90s tahoe
Looking at the 1997 Tahoe (350) and 2500 Suburban (454), there appear to be two starters, the standard is 1.4 kw and heavy-duty is 1.7 kw on the 454.
I would get this one :
TYC 106449L {#10465578} Info
One of our most popular parts
Permanent Magnet Gear Reduction; 1.7KW
$58.99 + $12 fedex ground shipping (to my address)
I just bought it (thanks) :)
Reactions: 67-468
I got one out of a junkyard for $20 off a late 90s 350 tahoe and had it on my 10:1 454. Best little starter ive ever had.
The answer to all starter questions;
1) If you have the 168-tooth flywheel/flexplate, get an ACDelco starter for a 96 Tahoe
2) If you have the 153-tooth flywheel/flexplate, get an ACDelco starter for a 96 Impala SS
Reactions: Ericnova72
one of the best upgrades to our '70 was the gm 19302919 starter. have had it for a little over a year and is GREAT so far. just be sure to use the correct bolts, gm bolt part# 12338064 i believe. good luck!
1 - 14 of 14 Posts
