My gas gauge reads very full all the time. Following the advice in another thread I checked ground on my gas tank. I connected a meter between the actual tank and frame and had continuity. I took the the other wire off and connected it to ground which made the gauge drop down to empty.
Does this mean its the sending unit? Other ideas?
I took the ground wire off. Ground down to bare metal on all surfaces. Put it back together and Viola.... Still didn't work. So I just ordered a new sending unit. Should be here mid week. Need to drive it until the tank runs dry!
The sending unit itself has a ground on top of the actual sending unit.
