Is it possible to replace the sending unit without dropping the gas tank. :confused: Gas tank will be empty of course. It appears there is enough room. The car is a 1966 Malibu convertible.
Originally posted by rett69:
My gas gauge is stuck on full (wish it was full all the time....
) Would it be a ground problem, sending unit problem????
Need to do a couple of tests to see which one it is. This should give you an idea on how to do it. On the 69 there is a 3rd wire (black) to the meter. That's the meter ground. Could be:
An open meter ground.
An open sender wire.
A stuck sender, though that won't be my first guess.
http://www.chevelles.com/forum/ultimatebb.php?ubb=get_topic;f=22;t=003680
